How to quickly delete feed data?
by GPSSerbia on Sun Jul 02, 2017 8:07 am
My feed graph shows data from 15 days in the past, even when all data from that period are deleted. Is it possible to force the graph to show only what is in the feed?
Also, how to clear feed data within date range, not page-by-page?
Thank you for quick answer.
GPSSerbia
Re: How to quickly delete feed data?
by osterstone on Mon Jul 03, 2017 9:16 am
I have the same problem
osterstone
by jwcooper on Wed Jul 05, 2017 11:41 am
At this time you would either want to delete all data for your feed, or create a new chart on a dashboard that selects the time range you would like. Plan is to add time range selections to the feed page, but just not there yet.
jwcooper
by GPSSerbia on Wed Jul 05, 2017 8:00 pm
OK, thank you for your answer.
GPSSerbia
by tomtheriverguide on Thu Nov 30, 2017 12:56 am
I have the same/a similar issue. I deleted a bunch of data from the feed listing below the graph. After doing that, the graph said there was no data - as expected. It continued to behave that way. Then I tried downloading all my data (not sure if that is relevant - seems like it should be unrelated) and the graph began showing all the data points, even the ones deleted, even though they do not show on the list below the graph.
tomtheriverguide
by jwcooper on Thu Nov 30, 2017 4:27 pm
We'll look into this issue, and thanks for the information. It should help us track this issue down.
jwcooper
by Kees7777 on Sat Jul 13, 2019 4:21 pm
We are 2 years further in the future, but the problem is not solved yet. How to clear a block of data ?
Kees7777
