Hi all!
When I try to use io.statusText() inside void loop() to print the current status of connection to serial monitor and also adalogger, an incorrect status is shown:
"Network disconnected."
However values are clearly updated on Adafruit IO feeds (the connection is active and working).
Is there something that I may be missing? additional code or something to get the correct connection status? Or does io.statusText() not work inside void loop() ?
io.statusText() not showing right status
