Aio.send error
lostcity
Aio.send error
Post by lostcity »
I get the following error message with my python script. I has worked well for a a couple of days but now produces this error message:
File "Thermometer.py", line 37, in <module>
aio.send('My_Garage',read_temp())
File "/usr/local/lib/python2.7/dist-packages/Adafruit_IO/client.py", line 90, in send
return Data.from_dict(self._post(path, {'value': value}))
File "/usr/local/lib/python2.7/dist-packages/Adafruit_IO/client.py", line 72, in _post
self._handle_error(response)
File "/usr/local/lib/python2.7/dist-packages/Adafruit_IO/client.py", line 56, in _handle_error
raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found
jerryn
Re: Aio.send error
Post by jerryn »
I was having the same problem starting a few hours ago. I discovered that if I removed the underscore from my feed name, it started working again. I changed it from basement_temperature to basementtemperature and it now works. Your mileage may vary ....
jerryn
Re: Aio.send error
Post by jerryn »
It appears that this is now strictly enforced!
from the guide: https://learn.adafruit.com/adafruit-io-basics-feeds
Name - A short descriptive title of your data. Letters, numbers, and spaces are valid characters, and this field is required. The feed name must be unique for your account.
lostcity
Re: Aio.send error
Post by lostcity »
jerryn wrote:I was having the same problem starting a few hours ago. I discovered that if I removed the underscore from my feed name, it started working again. I changed it from basement_temperature to basementtemperature and it now works. Your mileage may vary ....
Thanks, I removed the underscore and eureka! now it works. I replaced the underscore with a hyphen. Will see what this produces.
Thanks for the response and tip.
tvoverbeek
Re: Aio.send error
Post by tvoverbeek »
My feeds started failing yesterday with the same error:
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found.
I am using the REST API.
I was using the 'human readable name' in aio.send().
Replacing it with the key (all lowercase, no spaces, hyphens allowed) made it work again.
I guess this is all in preparation for IO going out of Beta next month.
lostcity
Re: Aio.send error
Post by lostcity »
Well it started working but then it pooped out on me. Back to the Drawing Board
jerryn
Re: Aio.send error
Post by jerryn »
Mine is still working. No hyphens...
lostcity
Re: Aio.send error
Post by lostcity »
jerryn wrote:Mine is still working. No hyphens...
I think I found my problem. Sometime back I created a new dashboard along with a feed by the same name (doh!). Once I deleted that and made the changes noted above it seems to be working. So far, a solid hour of data.
jerryn
Re: Aio.send error
Post by jerryn »
I learned about this link and a recent update on the "discord" site today.
https://learn.adafruit.com/naming-thing ... troduction
lostcity
Re: Aio.send error
Post by lostcity »
jerryn wrote:I learned about this link and a recent update on the "discord" site today.
Feed is still running, Thanks for the link. Much appreciated.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
