I got it working, i reverser engineered the data format and also had to change to mqtt
Here is how to format the gps data
while True:
d = OrderedDict()
d['value'] = 23
d['lat'] = gpsd.fix.latitude
d['lon'] = gpsd.fix.longitude
d['ele'] = gpsd.fix.altitude
print "dump:",json.dumps(d)
client.publish('gpsmapdata',json.dumps(d))
time.sleep(10)
Here is my entire program
# Example of using the MQTT client class to subscribe to and publish
# feed values. Author: Tony DiCola
# Import standard python modules.
import random
import sys
import time
import os
from gps import *
from time import *
import time
import threading
# Import Adafruit IO MQTT client.
from Adafruit_IO import MQTTClient
import json
from collections import OrderedDict
# Set to your Adafruit IO key & username below.
ADAFRUIT_IO_KEY = ''
ADAFRUIT_IO_USERNAME = '' # See https://accounts.adafruit.com
# to find your username.
class GpsPoller(threading.Thread):
def __init__(self):
threading.Thread.__init__(self)
global gpsd #bring it in scope
gpsd = gps(mode=WATCH_ENABLE) #starting the stream of info
self.current_value = None
self.running = True #setting the thread running to true
def run(self):
global gpsd
while gpsp.running:
gpsd.next() #this will continue to loop and grab EACH set of gpsd info to clear the buffer
# Define callback functions which will be called when certain events happen.
def connected(client):
# Connected function will be called when the client is connected to Adafruit IO.
# This is a good place to subscribe to feed changes. The client parameter
# passed to this function is the Adafruit IO MQTT client so you can make
# calls against it easily.
print('Connected to Adafruit IO! Listening for DemoFeed changes...')
# Subscribe to changes on a feed named DemoFeed.
#client.subscribe('DemoFeed')
def disconnected(client):
# Disconnected function will be called when the client disconnects.
print('Disconnected from Adafruit IO!')
sys.exit(1)
def message(client, feed_id, payload):
# Message function will be called when a subscribed feed has a new value.
# The feed_id parameter identifies the feed, and the payload parameter has
# the new value.
print('Feed {0} received new value: {1}'.format(feed_id, payload))
# Create an MQTT client instance.
client = MQTTClient(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
# Setup the callback functions defined above.
client.on_connect = connected
client.on_disconnect = disconnected
client.on_message = message
# Connect to the Adafruit IO server.
client.connect()
# Now the program needs to use a client loop function to ensure messages are
# sent and received. There are a few options for driving the message loop,
# depending on what your program needs to do.
# The first option is to run a thread in the background so you can continue
# doing things in your program.
client.loop_background()
# Now send new values every 10 seconds.
print('Publishing a new message every 10 seconds (press Ctrl-C to quit)...')
gpsp = GpsPoller() # create the thread
gpsp.start()
while True:
d = OrderedDict()
d['value'] = 23
time.sleep(10)
