Hi, This is Sonia from ICbanQ purchasing department
As I write this forum is for RMA issue from we've ordered last Oct 17th Order #1569365-4475813805
P/N : HDMI 7" 800x480 Display Backpack - With Touchscreen, Q'ty of 1ea
PRODUCT ID: 2407
We've tried to connect with raspberry-PI, this LCD does not power on like attached picture.
It just has white & black line on it... for raspberry-PI that is connecting with this LCD, does not broken due work well with other LCD.
Seems this LCD is now out of stock, So we'd like to refund this order~
pls help to check and advise me shortly.
RMA )) HDMI 7" 800x480 Display Backpack - With Touchscreen
- icbanq
- Attachments
- ada3.png (980 KiB) Viewed 715 times
- ada2.png (695.38 KiB) Viewed 715 times
- ada1.png (839.54 KiB) Viewed 715 times
- adafruit_support_rick
Re: RMA )) HDMI 7" 800x480 Display Backpack - With Touchscre
Have you configured the config.txt file on the Pi?
Please see this tutorial:
https://learn.adafruit.com/adafruit-5-8 ... -pi-config
