Huzzah mqtt exception(3)
by chaplijt on Mon Nov 13, 2017 5:26 pm
I modified the Adafruit toilet light script (basically adding my info and deleting all of the neopixel stuff in an attempt to access my IFTTT data thru Adafruit.io. (from this: https://cdn-learn.adafruit.com/download ... -light.pdf)
it complies / uploads with message below (says done uploading) but the Huzzah does not go into execution until I hit reset. then red led is bright and blue flashes.
it connects to wireless ok but throws a mqtt exception 3 (shown below)
Archiving built core (caching) in: C:\Users\john\AppData\Local\Temp\arduino_cache_540482\core\core_esp8266_esp8266_huzzah_CpuFrequency_80,UploadSpeed_115200,FlashSize_4M3M_6dc93d3cbcff01773e2af5b79f320fbf.a
Sketch uses 231737 bytes (22%) of program storage space. Maximum is 1044464 bytes.
Global variables use 32608 bytes (39%) of dynamic memory, leaving 49312 bytes for local variables. Maximum is 81920 bytes.
Uploading 235888 bytes from C:\Users\john\AppData\Local\Temp\arduino_build_307971/abode_status_r0.ino.bin to flash at 0x00000000
................................................................................ [ 34% ]
................................................................................ [ 69% ]
....................................................................... [ 100% ]
⸮Smart Toilet Light with ESP8266
Connecting to NETGEAR
WiFi connected
IP address:
192.168.2.115
Connecting to MQTT...
Exception (3):
epc1=0x4000bf3c epc2=0x00000000 epc3=0x00000000 excvaddr=0x4023001c depc=0x00000000
ctx: cont
sp: 3ffef520 end: 3ffef750 offset: 01a0
>>>stack>>>
3ffef6c0: 40105072 0000000b 3ffe8487 3ffee724
3ffef6d0: 3fffdad0 3ffee51c 3ffee51c 40202e62
3ffef6e0: 3ffe848c 3ffee608 3ffee6f8 3ffee724
3ffef6f0: 3ffe85e0 3ffee608 3ffee6f8 3ffee724
3ffef700: 00000003 3ffee51c 3ffee6f8 40201d76
3ffef710: 3fffdad0 00000000 3ffee71c 40201dbc
3ffef720: 3ffe8728 7302a8c0 feefeffe 3ffee724
3ffef730: 3fffdad0 00000000 3ffee71c 402035a8
3ffef740: feefeffe feefeffe 3ffee730 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
chaplijt
