IOT graph max value not working
by DBaril on Tue Dec 26, 2017 6:17 am
The Maximum value of the graphs in my dashboard are not being applied. The code I am using is the same than your example/tutorial for the Adafruit Huzzah.
A workaround to that: I will add a Max value "filtering IF" in the publishing code. I will try later tonight.
Please see attached screenGrab.
TempMaxValue
HumidityMaxValue
D.
DBaril
Re: IOT graph max value not working
by btreichel on Tue Dec 26, 2017 12:15 pm
Yep, I've also noticed that they seem to be more initial scaling than anything else.
btreichel
by abachman on Fri Dec 29, 2017 11:51 am
Hi DBaril!
I can take a look at that issue, we've had problems wrestling with the graphing library in the past (https://www.metricsgraphicsjs.org/) and _sometimes_ get it all sorted out, but edge cases still catch us. I'll update this thread when I have any new information for you.
- Adam B.
abachman
by abachman on Fri Dec 29, 2017 12:53 pm
DBaril, good news! Easy fix (I think).
I was seeing the same bug on my end and with the fix it works as expected. I can constrain a chart with outliers arbitrarily:
Screen Shot 2017-12-29 at 11.50.21 AM.png (8.75 KiB) Viewed 139 times
Can you take a look at your dashboard and make sure the fix is effective for your case?
- adam
abachman
