Value of pointer in IF statement (subscribing)
by UberPsych on Thu Dec 28, 2017 9:20 am
I am subscribing to a feed called button04. The pointer value when printed is either ON or OFF.
I tried the IF ELSE statement I get an error.
if (*data->value() == "ON") {
// Do something
else
// OFF
I suspect that that I need to copy the pointer value into a char[3] and then compare but all my attempts have failed.
UberPsych
Re: Value of pointer in IF statement (subscribing)
by abachman on Fri Dec 29, 2017 3:14 pm
Hey UberPsych,
You could use the toString method on the data object to compare. In the case of your example code, assuming it's inside an Adafruit IO message handler, that would look like this:
void handleMessage(AdafruitIO_Data *data) {
  Serial.print("GOT DATA ");
  Serial.println(data->value());
  if (data->toString() == "ON") {
    doTheThing();
The Adafruit IO Arduino library has a handful of data conversion methods[/url] that are useful in cases like this: https://github.com/adafruit/Adafruit_IO_Arduino/blob/master/src/AdafruitIO_Data.h#L47-L70
- adam
abachman
by UberPsych on Fri Dec 29, 2017 11:01 pm
Thanks Adam
That fixed my problem.
UberPsych
