Why can't I begin Adafruit IO after the setup function
MaxMaeder
Post by MaxMaeder »
Why can't I begin Adafruit IO after the setup function? Every time I try to begin it with the code below, I cannot connect, but when I begin Adafruit IO before the setup function, it works perfectly. Why is this?
Adafruit_MQTT_Client mqtt(&client, aioServer, aioPort, aioUsername, aioKey); // Setup Adafruit IO
Adafruit_MQTT_Publish gpg = Adafruit_MQTT_Publish(&mqtt, urlGpg);
Adafruit_MQTT_Publish ppm = Adafruit_MQTT_Publish(&mqtt, urlPpm);
Adafruit_MQTT_Publish alerts = Adafruit_MQTT_Publish(&mqtt, urlAlerts);
Adafruit_MQTT_Subscribe iqOnOffButton = Adafruit_MQTT_Subscribe(&mqtt, urlWateriq);
abachman
Re: Why can't I begin Adafruit IO after the setup function
Post by abachman »
hi Max,
This is speculation / superstition and coming from my experience as a developer, but in situations like this if one way of organizing the code works and the other doesn't, stick with the one that works :D
If I had to guess, the Arduino IDE's conversion of your .ino file to a proper C++ project before compilation and the Adafruit MQTT library's use of constructors are interacting in a way that produces the behavior you describe. Stick with the pre-setup MQTT declarations.
- adam
