UPDATED IO CLIENT LIBRARY - REQUIRED UPDATE
by jwcooper on Wed Jan 31, 2018 12:00 pm
We have updated our io client library (https://github.com/adafruit/Adafruit_IO ... /tag/2.7.1) with 2.7.1.
This contains a new lastValue method (to get the last value sent in your feed), a small csv parsing fix, as well as updated ssl certificate fingerprints. This update is required if you are using secure connections. For any WiFi101 compatible boards, you'll need to use the Arduino WiFi 101 Firmware Updater to update SSL certificates.
The lastValue method will hopefully be useful for script startup to populate any existing values on device restarts, etc. You can find an example of usage in example sketch 01.
jwcooper
