IDEAS: DASHBOARD BLOCK SUGGESTIONS
Re: IDEAS: DASHBOARD BLOCK SUGGESTIONS
by brubell on Fri Jun 01, 2018 12:04 pm
JimboZA wrote:And I just thought of this one: I'm about to take my nodemcu offline to do some more coding. Some folk do have the url though, and may go for a look while it's down. A "down for maintenance" message would be nice.
While this is a temporary solution, it might be what's easiest for now - you can add a text element to your dashboard to show when it's offline.
brubell
by hoschi on Sat Jun 23, 2018 10:49 am
I would like to have a selectable time axis in line charts without editing the dashboard.
Right now I created several dashboards with different time scales for each topic.
Radio buttons on the right would be really handy, or a drop down list on the bottom of the line chart
hoschi
by flounder on Sun Aug 05, 2018 4:40 am
How about an RGB LED that takes 16-bit (Adafruit GFX) or 24-bit RGB info, plus a "blink rate" expressed as 0-255 units (0 is always on, 255 is blinking rapidly, figure out what the intermediate values mean)
flounder
by DrDetroit on Mon Aug 13, 2018 9:07 am
Show min/max values on the dial indicator ( as an arc in the outer ring) with a reset button
Settable hi/low danger values on the dial indicator, which synchronize with triggers or autogenerate them
IFTTT applet icons and status
Data rate vs limits / throttling mountain chart
Great setup - can't wait to see next versions come out!
DrDetroit
by brubell on Tue Aug 14, 2018 10:35 am
flounder wrote:How about an RGB LED that takes 16-bit (Adafruit GFX) or 24-bit RGB info, plus a "blink rate" expressed as 0-255 units (0 is always on, 255 is blinking rapidly, figure out what the intermediate values mean)
We recently added an indicator block which may be similar to what you're asking for: https://io.adafruit.com/blog/notebook/2 ... rd-blocks/
brubell
by orcrist on Tue Oct 02, 2018 1:11 pm
I asked this as a question on Discord, but maybe it's a request:
Linechart for boolean and other discrete/integer values. The current one averages all the 1's and 0's over time which is nonsensical. I want a chart that looks like a square wave for booleans.
e.g. this is what my chart looks like for a motion sensor with a couple of scattered triggers in the night:
orcrist
by bkx on Mon Nov 19, 2018 6:40 pm
How about a text entry?
User would type arbitrary text, press "enter" and the contents would be published to a topic.
This would probably be easy to implement and allow things like arm/disarm codes for a security system (from a public dashboard)
bkx
by brubell on Wed Nov 21, 2018 11:06 am
bkx wrote:How about a text entry?
The text block element does that, but it's not easily discoverable. The input field on it is "hidden", you can type right into it, and assign a feed to it.
brubell
by jdoscher on Wed Dec 05, 2018 11:51 am
Feature request- on line charts, give basic formatting options. Solid line, dashed line, dotted line, etc. Most importantly, give us the ability to set the color for each line.
jdoscher
by tommystotts on Tue Dec 18, 2018 5:22 am
Same indicator shows multiple levels of indication. In my case 3, ON, OFF, OUT green red yellow. I'm tracking NFC tag data for tools on a maintenance truck. 1st scan removes tool from truck (OUT) indicator goes red. 2nd scan returns tool to truck (ON) indicator goes green. Separate NFC tag takes tool away from truck (OFF, on loan to another truck) indicator goes yellow.
Could also be used as condition 1-70 indicator green, 71-85 indicator yellow, 86-100 red.
tommystotts
by ReubenFinch on Thu Feb 14, 2019 5:57 pm
Allow multiple location feeds to the same map.
It would be wonderful to be able to post multiple locations to a map.
Also it would be advantageous to be able to send "waypoints" in addition to the current track-points.
Way points are not linked by a line, and perhaps have a different colour.
ReubenFinch
by nickfixit on Sat Mar 30, 2019 9:27 am
A Boolean Chart has been suggested. I want one too.
This should have a line that looks like a square wave changing between the binary values.
The Y axis should be capable of being labeled for the 2 states in text so you can name the 2 states.
A bonus would be to be able to stack up more than one binary data stream in the same chart, like a multi trace digital scope screen, and label them accordingly. The important theing here is that the timescales line up for the streams.
An alternate is to have the streams each in its own chart but have the timescales capable of being synchronized so that the events can be correlated.
You can see this 2 state chart looks nasty with the slopey lines. The last value should be maintained until the new value comes.
door graph.png (24.16 KiB) Viewed 125 times
Another option would be to use the analog chart but make the data stay at the last value until a new value is obtained then step to the new value as a chart option. THis would do it too. Suppressing the decimal points on the 1/0 Y axis would also be needed.
nickfixit
by mpc823 on Sun May 19, 2019 8:28 pm
Just wanted to say that I, too, would like a Boolean Line chart. For values that are only 0 & 1, this type of chart would be much preferable to the line chart we have now.
mpc823
