I have my data feeds shared and everything works as expected.
From a completely separate machine I can run the following command....
curl -s "https://io.adafruit.com/api/v2/<myid>/feeds"
curl -s "https://io.adafruit.com/api/v2/<myid>/feeds/<feedkey>/data"
This is where it gets unexpected. I can run the following command...
curl -s -X DELETE "https://io.adafruit.com/api/v2/<myid>/feeds/<feedkey>/data/<data point id>"
Is this operating as designed? Am I missing something obvious?
thanks!
