IFTTT Send Data To Adafruit IO Action Skipped
by ldaponte on Thu Apr 05, 2018 5:22 am
First time hooking up IFTTT to Adafruit IO. I have an IFTTT button widget that triggers an Adafruit send data. I am able to link my Adafruit.io account to IFTTT and I can select from my already configured IO feeds. I select one of my feeds that has been working or even create a new feed - public or private and I'm not able to get the data to successfully send to my IO feed from IFTTT. The IFTTT activity log either says action skipped or action failed with no reason given. I watch the feed data in IO and nothing shows up. I can via an MQTT client send data to my IO feeds and data shows and I can chart it etc. In my Adafruit IO account under connected services I can see that IFTTT is connected. I've also tried the IFTTT "check now" button to trigger but still no data arriving in the IO feed. Do I require a paid IO account for this to work?
Larry
ldaponte
Re: IFTTT Send Data To Adafruit IO Action Skipped
by ArtOfStuttering on Sun Apr 08, 2018 12:23 pm
Unfortunately, I'm having the exact same issue. If anyone could clarify this behavior, please let us know!
ArtOfStuttering
by ldaponte on Tue Apr 10, 2018 2:03 am
I was able to work around this by using an IFTTT Web Hook to post to the Adafruit feed API but would still like to know what is wrong with the IFTTT Adafruit action.
ldaponte
by leoz on Thu Nov 29, 2018 9:57 am
The same here right now.
Any solutions?
leoz
by brubell on Thu Nov 29, 2018 10:45 am
leoz wrote:The same here right now.
Any solutions?
Are you using the Adafruit IO IFTTT action from https://ifttt.com/adafruit ?
Does it show skipped? Does the action occur, but it displays as skipped?
brubell
by leoz on Thu Nov 29, 2018 5:18 pm
brubell wrote:Are you using the Adafruit IO IFTTT action from https://ifttt.com/adafruit ?
Yes
brubell wrote:Does it show skipped? Does the action occur, but it displays as skipped?
I've checked now, see "Action skipped" and "Applet failed", action has never start.
Recently changed the password but afterwards i've associated the account again.
I've used webhooks to get a workaround, thanks!
leoz
by FlaminMad on Fri Dec 28, 2018 10:48 am
Afternoon all,
I've also just connected Adafruit and IFTTT and am experiencing the same issues.
I've done some experimenting and it seems that if the feed is not in the default group only, then the service fails to run with the error:
'Adafruit error: Unable to locate feed operator or value'
So for example, I have a group named 'Printer' with feed 'OnOffControl', which fails when I try to write 'OFF' to with IFTTT. However, if I create a feed called test just under the default group, I can successfully write 'OFF' with no problems.
Unfortunately I'm a couple of days into this game so have absolutely no idea how to troubleshoot the findings! Hopefully this helps if anyone's working on the issue (Do I need to raise on Github?)- Ill go and look for webhooks in the meantime as suggested above.
Thanks everyone!
FlaminMad
FlaminMad
by brubell on Fri Dec 28, 2018 11:51 am
FlaminMad wrote:Afternoon all,
Thanks everyone!
FlaminMad
Thanks for doing testing on this, I'll add it to the FAQ.
brubell
