MQT Subscription error - Not authorized
by TomasBray on Wed Apr 25, 2018 8:51 am
I've just connected a simple relay switch to a Wemos D1 mini using the 'RelayControlV2' code by ItKindaWorks on Github. It seems to be connecting to the server fine but I am getting the following error message in the live errors monitor:
2018-04-25 22:34:56 mqtt subscription error on /feeds/beckys-lamp: you are not authorized
I've double checked the AIO key and can't think what else could be wrong.
TomasBray
Re: MQT Subscription error - Not authorized
by abachman on Thu Apr 26, 2018 12:16 pm
Hi Tomas,
One thing to check is that you're including your username in the MQTT topic, that means if you're "tomasbray" on IO, the topic would be "tomasbray/feeds/beckys-lamp" rather than "/feeds/beckys-lamp". Also make sure there's not a leading slash: "tomasbray/feeds/beckys-lamp" but not "/tomasbray/feeds/beckys-lamp".
- adam
abachman
by TomasBray on Fri Apr 27, 2018 9:39 pm
Brilliant!
Thanks Adam.
TomasBray
