API v2 .../data/last not working?
by thayes on Thu May 03, 2018 9:44 am
The API says use this to fetch all data:
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data
And this to fetch the most recent entry:
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data/last
The first one work for me, and I get a big array of values. The second one results in this error:
{"error":"not found - API documentation can be found at https://io.adafruit.com/api/docs"}
Since the only difference between the two calls is appending "/last" to the URL I'm pretty sure that it isn't a bug in my code, an authentication problem (its a public feed also), etc.
What's going on? Is this a bug? Is the API documentation incorrect? Am I misunderstanding something?
thayes
Re: API v2 .../data/last not working?
by thayes on Thu May 03, 2018 9:50 am
Maybe I just answered my own question. Although it is a public feed I can't request ../data/last without authenticating?
This works and gives me the last point:
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data/last?X-AIO-Key=blah
An unauthenticated user can pull *all* data from a public feed but not individual data points?
thayes
by cimba007 on Sat Sep 22, 2018 6:02 pm
Ran into the same problem .. still no fix?
cimba007
by brubell on Sun Sep 23, 2018 4:57 pm
You can add support for this using the MQTT /get topic modifier, added to the Adafruit IO Arduino library v2.7.3+: https://io.adafruit.com/blog/notebook/2 ... etain-flag. This feature is compatible with both feeds and group topics: https://github.com/adafruit/Adafruit_IO ... ub.ino#L51
brubell
