Feed times "in 4 hours"
by jerryn on Tue May 22, 2018 6:37 am
The "recored time" on my feeds recently started showing up as "in 4 hours" I suspect this is a GMT thing - I am in TZ UTC-4. If I open the feed it shows the current time in my local time. Is there a setting to correct this?
FEEDS page showing "In 4 hours"
single feed details - Time in Local Time - this is am2320 feed - snapped short time later so the data value is not the same.
jerryn
Re: Feed times "in 4 hours"
by kennethm4 on Tue May 22, 2018 1:35 pm
Getting the same here in the US. No idea why.
Ken
kennethm4
by abachman on Tue May 22, 2018 5:15 pm
(reposting from Discord)
Yep, seeing the same. Found the bug though.
We replaced the backend code that did feed loading last week and got a big speed boost, especially for folks with more feeds (cut loading time > 50% in most cases). BUUUT the time formatting changed just slightly, but enough that our frontend time rendering library (moment.js) started interpreting the times as local to your browser instead of as UTC, which they actually are.
before: "2018-05-22T12:13:14.123Z"
after (w/ bug): "2018-05-22 12:13:14.123"
We've reverted the time formatting coming from IO and your Feeds page should now show the correct time.
- adam
abachman
by jerryn on Tue May 22, 2018 5:17 pm
Thank you! It seems to be working fine now!
jerryn
by kennethm4 on Wed May 23, 2018 12:16 pm
Thank tou for fixing this! Adafruit rocks!!
kennethm4
cron
