LASTVALUE METHOD FOR Adafruit_MQTT LIBRARY
by sayedurrchowdhury on Sun Jun 03, 2018 4:30 pm
Like you have described (viewtopic.php?f=56&t=130325) a "lastValue" method in Adafruit IO library (Arduino), do we have an equivalent in Adafruit_mqtt library (ESP8266)?
I tried using Adafruit_IO with ESP8266, but couldn't get past the compiler errors. Please help.
sayedurrchowdhury
Re: LASTVALUE METHOD FOR Adafruit_MQTT LIBRARY
by brubell on Mon Jun 04, 2018 10:38 am
Could you post the compiler errors from Arduino?
brubell
by abachman on Tue Jun 05, 2018 1:47 pm
Sayed,
lastValue is part of the HTTP API, so it can't be called from the Adafruit_MQTT library, you'd have to use an HTTP library to make the call.
But, since we added that feature, we also added an MQTT-based method of retrieving the last value for a feed (similar to MQTT's retain feature) that may be helpful in your case. I've published a script that demonstrates its use with the Adafruit_MQTT library here: https://gist.github.com/abachman/f6c2c4 ... 10ac580c0d
The key parts are setting up the subscription feed that should receive the last value and the publishing feed that will trigger it:
// Notice MQTT topics for AIO follow the form: <username>/feeds/<feedname>
// and the get topic adds `/get` to the feed topic you want to receive the value on.
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/onoff");
Adafruit_MQTT_Publish onoff_get = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/onoff/get");
And then, actually triggering the resend looks like this:
onoff_get.publish(0);
In the example sketch I included the .publish call in the MQTT_connect function so that it's triggered whenever the device has to reconnect for any reason (power cycling, wifi interference, transient network errors, etc.).
- adam b.
abachman
by infov0re on Wed Jun 13, 2018 5:59 pm
Bingo! This solves the issue I was having in this thread - viewtopic.php?f=56&t=135762 - the key is to send the null byte only when you know you have a connection to Adafruit IO. Thanks, Adam.
infov0re
