Not sure if this is the right area, but there were other MQTT questions in here.
I have been using the Adafruit MQTT library with the Huzzah ESP8266 with a Mosquitto broker (1.4.14) running on a raspi. This then communicates with OpenHab2. This works very well and I like the Huzzah part.
I have a need for more IO at one location and plan to use an Arduino Mega with an ethernet shield. (I plan to use most of the analog and 10-15 of the discrete inputs).
I expected to use my code from the the ESP applications with minor changes (Ethernet instead of wifi library, etc.) and all the IO stuff for the inputs.
The first test I ran was just a sending a single number "25".
The Mega connects to ethernet and I can ping it fine. It hangs at the “MQTT Connect” function. The error code is "1", "connection refused, unacceptable protocol version".
I have used MQTT Spy to watch Mosquitto. From what I can tell, I don’t see anything suspicious. I can inject messages for the tag and they show up in Openhab.
Thanks for any help.
The program:
//Mega Adafruit MQTT_Home_rev 0
// Update: 6/09/18
#include <SPI.h>
#include <Ethernet.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
// MAC address for your Ethernet shield
byte mac[] = { 0xDE, 0xBE, 0xBE, 0xEF, 0xFE, 0xfD };
//0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED original
//0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED other
/************************* MQTT Broker Setup *********************************/
#define mqtt_server "BANNED"
#define mqtt_serveport 1883
#define mqtt_username "BANNED"
#define mqtt_password "xxxxx"
EthernetClient client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, mqtt_server, mqtt_serveport, mqtt_username, mqtt_password);
// Setup a feed called 'MegaA00' for publishing.
Adafruit_MQTT_Publish MegaA00 = Adafruit_MQTT_Publish(&mqtt, "openhab/in/MegaA00/state");
Serial.begin(115200);
delay(10);
Serial.println(F("Mega Adafrut MQTT rev 0"));
while (Ethernet.begin(mac) != 1)
Serial.println("Error getting IP address via DHCP, trying again...");
delay(15000);
Serial.println("IP address: "); Serial.println(Ethernet.localIP());
delay(5000);
Serial.println("before MQTT connect");
MQTT_connect();
Serial.println("after MQTT connect");
float x=25;
// Ensure the connection to the MQTT server is alive (this will make the first
// connection and automatically reconnect when disconnected). See the MQTT_connect
// function definition further below.
MQTT_connect();
// Publish to MQTT
Serial.print(F("\nSending value "));
Serial.print(x);
Serial.print("...");
if (! MegaA00.publish(x++)) {
Serial.println(F("Failed"));
} else {
Serial.println(F("OK!"));
// ping the server to keep the mqtt connection alive
if(! mqtt.ping()) {
mqtt.disconnect();
delay(1000);
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
int8_t ret;
Serial.println("mqtt connect routine");
// Stop if already connected.
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
Serial.println("wait");
delay(5000); // wait 5 seconds
Serial.println("MQTT Connected!");
Adafruit MQTT
