Got lost on mqtt.readSubscription
by MSPAdafruitIO on Fri Jun 29, 2018 10:24 am
Hi folks,
i got lost on mqtt.readSubscription. I'm able to read data from my feed. As soon as I change the value on the dashboard it shows up on the Nodemcu.
What I understood so far is that the MQTT_Subscribe is waitint for a message.
My idea is to read data on startup of the Nodemcu and than continue with waiting for new data.
Any idea how I can read the last data value with the mqtt lib?
THX for help
Gerhard
MSPAdafruitIO
Re: Got lost on mqtt.readSubscription
by brubell on Fri Jun 29, 2018 11:43 am
If you want to have your client wait for subscription updates, before the loop, implement:
client.loop_background()
which runs a thread in the background so you can continue doing things in your script.
or
client.loop_blocking()
which runs a message loop forever. If you just want to listen to an event, implement this.
Then, when the on_message callback calls the message method (https://github.com/adafruit/io-client-p ... ent.py#L34), save the incoming payload to a new value.
brubell
by MSPAdafruitIO on Fri Jun 29, 2018 12:13 pm
Hi brubell,
thx for answer.
Let me explain better.
Nodemcu is starting. Let's say due to power fail or so.
1.) During start I want to read the last value of the feed just to continue from the last value.
2.) After that I'm waiting for messages and I read the value
2.) Is ready, working fine and I'm able to read. No Problem
The question is on 1.) During start I don't have a pending message because all messages are processed by the client.
How can I force the server to give me the last values of an feed or how can I read the value by myself?
Cu
Gerhard
MSPAdafruitIO
by brubell on Mon Jul 02, 2018 2:23 pm
You can get the previous point of data from IO by getting previousData
https://io.adafruit.com/api/docs/#opera ... eviousData
brubell
