automatic feed registration
by doi on Fri Jun 29, 2018 12:03 pm
I set up several ESP8266 device up that register with there mac address a MQTT feed in Adafruit io. using the Adafruit MQTT library. Since I deleted some feeds that I don't need, new devices can not register themself anymore. Could you please look in this problem.
BR
Christian
doi
Re: automatic feed registration
by brubell on Mon Jul 02, 2018 9:51 am
doi wrote:I set up several ESP8266 device up that register with there mac address a MQTT feed in Adafruit io. using the Adafruit MQTT library. Since I deleted some feeds that I don't need, new devices can not register themself anymore. Could you please look in this problem.
BR
Christian
Feeds using the Adafruit IO Arduino library (https://github.com/adafruit/Adafruit_IO_Arduino) should be automatically generated when they're set up in the sketch. If you're using an ESP8266 device, consider moving over to that this library - it's more recently updated.
brubell
cron
