Are Notifications Working?
by jacobgarner123 on Fri Jul 06, 2018 10:40 am
I am trying to get notified if a feed stops getting data after 10 minutes. I left my device off overnight just to make sure, and I didn't get an email. Am I missing something, or is it not working?
jacobgarner123
Re: Are Notifications Working?
by brubell on Fri Jul 06, 2018 5:27 pm
We currently do not have this functionality enabled from Adafruit IO.
You might want to use an service which integrates with Adafruit IO, we have two:
If-This-Then-That: https://learn.adafruit.com/using-ifttt-with-adafruit-io, https://ifttt.com/adafruit
or Zapier: https://learn.adafruit.com/using-zapier ... dafruit-io
Both of these services are able to perform the notification and comparison that you're looking for.
brubell
by jacobgarner123 on Sat Jul 07, 2018 1:33 am
Is it just temporarily turned off? Why is it an option?
Also, I noticed I am not getting emails from a trigger I set up. Are those working, or at this point do I just need to do a support ticket?
jacobgarner123
by brubell on Mon Jul 09, 2018 10:29 am
jacobgarner123 wrote:Is it just temporarily turned off? Why is it an option?
They are temporarily turned off (we'll hide them).
Is this an IFTTT trigger, or a trigger from Adafruit IO?
brubell
by jacobgarner123 on Tue Jul 10, 2018 6:03 pm
I have an adafruit.io trigger that is supposed to send me an email when the feed hits a certain value, and it doesn't work.
jacobgarner123
by brubell on Wed Jul 11, 2018 10:34 am
jacobgarner123 wrote:I have an adafruit.io trigger that is supposed to send me an email when the feed hits a certain value, and it doesn't work.
Try using this IFTTT recipe, it does exactly what the trigger on Adafruit IO should be doing: https://ifttt.com/applets/317329p-if-a- ... he-details
brubell
by jacobgarner123 on Wed Jul 18, 2018 7:44 pm
Is there a way to use IFTTT to get notified when the feeds stops getting data? I haven't been able to think of a way to make that happen.
Is there a timeline for getting notifications up and running?
jacobgarner123
by brubell on Thu Jul 19, 2018 9:16 am
jacobgarner123 wrote:Is there a way to use IFTTT to get notified when the feeds stops getting data? I haven't been able to think of a way to make that happen.
It'd be a bit complicated, but you'd check if the data is the same value (you need a feed which should change at least once a day). If the feed hasn't "updated" in the past X hours, send an email.
Adafruit IO notifications will be restored within the next few weeks.
brubell
by jacobgarner123 on Sat Oct 20, 2018 10:47 am
Any word on this? It still doesn't seem to work...
jacobgarner123
