PEM file for Adafruit.io
by jaada on Sun Jul 08, 2018 12:02 pm
I'm trying to run a MQTT client on a Raspberry PI that's requiring a .pem ca file to enable TLS.
I'm at a loss on how to do this. Any suggestions?
Thank you in advance!
jaada
Re: PEM file for Adafruit.io
by brubell on Mon Jul 09, 2018 10:26 am
Are you trying to connect the Pi to Adafruit IO?
Could you provide a link to the library and your implementation.
If you want a MQTT Library/Client that works with Adafruit IO, consider importing the IO-Client-Python's `mqtt_client.py` (https://github.com/adafruit/io-client-python) into your python script.
brubell
by jaada on Mon Jul 09, 2018 10:47 am
Thank you so much for the reply!
I’m using the following code:
https://github.com/jpwsutton/status/blo ... /status.py
jaada
by brubell on Mon Jul 09, 2018 11:37 am
No problem! You seem to be using the same MQTT client library as we do in io-client-python (paho mqtt)
Instead of using the ca file, we can do a call to self._client.tls_set_context() (https://github.com/eclipse/paho.mqtt.py ... et_context)
Here's the implementation we went with:
https://github.com/adafruit/io-client-p ... ent.py#L58
brubell
