Huzzah32 - Adafruit. IO Example Compilation Error
by maciekwrc on Mon Jul 09, 2018 12:10 pm
I've been trying to connect my Huzzah32 to the Adafruit IO using example codes but they do not compile for Huzzah32.
Any idea what is wrong?
Appreciate some hints.
Alternatively, do you know where I can find any working sample code for Uzzah32 for Adafruit IO?
(Huzzah32 is working fine with the Bosch 680 sensor, I can see correct readings in the Serial Monitor)
Regards,
Maciek
Arduino: 1.8.5 (Windows 10), Board: "Adafruit ESP32 Feather, 80MHz, 115200, None"
IC:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\hardware\espressif\esp32\libraries\WiFi\src" "-IC:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\hardware\espressif\esp32\libraries\WiFiClientSecure\src" "C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_428353\src\AdafruitIO_Feed.cpp" -o "C:\Users\Maciek\AppData\Local\Temp\arduino_build_645346\libraries\arduino_428353\AdafruitIO_Feed.cpp.o"
C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_428353\src\AdafruitIO_Feed.cpp: In member function 'AdafruitIO_Data* AdafruitIO_Feed::lastValue()':
C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_428353\src\AdafruitIO_Feed.cpp:207:1: error: control reaches end of non-void function [-Werror=return-type]
cc1plus.exe: some warnings being treated as errors
Multiple libraries were found for "WiFi.h"
 Used: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\hardware\espressif\esp32\libraries\WiFi
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library arduino_428353 at version 2.7.4 in folder: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_428353
Using library arduino_706850 at version 0.20.1 in folder: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_706850
Using library arduino_562809 at version 0.3.1 in folder: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\libraries\arduino_562809
Using library WiFi at version 1.0 in folder: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\hardware\espressif\esp32\libraries\WiFi
Using library WiFiClientSecure at version 1.0 in folder: C:\Users\Maciek\Dropbox\WELLcube\ARDUINO_Code\hardware\espressif\esp32\libraries\WiFiClientSecure
exit status 1
Error compiling for board Adafruit ESP32 Feather.
maciekwrc
Re: Huzzah32 - Adafruit. IO Example Compilation Error
by brubell on Mon Jul 09, 2018 1:13 pm
The Adafruit IO Arduino Library (https://github.com/adafruit/Adafruit_IO_Arduino) has examples which are tested with the Huzzah32, Huzzah8266, and M0 WiFi.
Do any of those compile for you?
brubell
by maciekwrc on Mon Jul 09, 2018 8:21 pm
Yes I've been using example sketches from this library, downloaded via libraries manager in the Arduino IDE.
I always get the same errors for those sketches.
I have also tried some examples from Huzzah32 libraries and they work fine. It connects to WiFi and transmits data.
One error is related to this;
The other one shows that I've got doubled WiFi.h libraries.
One from AdafruitIO another from Huzzah WiFi examples. Shall I delete one of them?
Maciek
maciekwrc
by brubell on Tue Jul 10, 2018 9:52 am
maciekwrc wrote:The other one shows that I've got doubled WiFi.h libraries.
You'll want to keep the WiFi.h from the Adafruit IO Library. Try uninstalling the Huzzah WiFi library and testing with that, let me know how it goes.
brubell
