WiFi Provisioning
- smcneese
WiFi Provisioning
Hey all! I am evaluating adafruit.io and other IoT platforms and was wondering if anything exists for provisioning devices? For example, the device we built needs to be connected to a end-users wifi. Obviously we cannot hard code the SSID/password into the code running on the device.
- brubell
- Learn User Page
Re: WiFi Provisioning
The Adafruit IO Arduino library requires hardcoding of the end-user's wifi network SSID and password to be stored in flash.
Your use case may be better suited to running the Adafruit IO Python Client (https://github.com/adafruit/io-client-python) on a Raspberry Pi or another small linux board.
You can SSH into the board (headless) to interact with the Adafruit IO client, and the board's network card during evaluation. How do you plan on provisioning the other IoT platforms?
- smcneese
In a normal provisioning process for a mass produced IoT device, the end user needs to establish connection of the device to their WiFi network. One way is for the device to startup in server mode allowing WiFi connections and hosting a web page. The user would connect to the device SSID and be service a config page in the browser. The user enters in their local WiFi ssid and password then the device changes to a client and connects to their WiFi.
The more complicated your device is the more that needs to happen. For example the unique device might need to be registered to the users account by MAC or some other unique ID.
The adafruit.io service appears to be more for the hobbyist and not for commercial IoT devices.
