Here is the analysis of the error
PC: 0x400d3da5: AdafruitIO_Group::call(AdafruitIO_Data*) at /Users/flounder/Documents/Arduino/libraries/arduino_283704/src/AdafruitIO_Group.cpp line 218
EXCVADDR: 0xfefefefe
Decoding stack results
0x400d3e45: AdafruitIO_Group::subCallback(char*, unsigned short) at /Users/flounder/Documents/Arduino/libraries/arduino_283704/src/AdafruitIO_Group.cpp line 263
0x400d4470: Adafruit_MQTT::processPackets(short) at /Users/flounder/Documents/Arduino/libraries/Adafruit_MQTT_Library/Adafruit_MQTT.cpp line 444
0x400d39c6: AdafruitIO::run(unsigned short) at /Users/flounder/Documents/Arduino/libraries/arduino_283704/src/AdafruitIO.cpp line 171
0x400d2181: loop() at /Users/flounder/BANNED/Projects/inout/inout_group/inout_group.ino line 401
0x4013fd9e: loopTask(void*) at /Users/flounder/Library/Arduino15/packages/esp32/hardware/esp32/1.0.0-rc3/cores/esp32/main.cpp line 17
void AdafruitIO_Group::call(AdafruitIO_Data *d)
// uint8_t i; // jmn
if(_groupCallback == NULL) {
return;
AdafruitIOGroupCallback *cur_cb = _groupCallback;
while(cur_cb) {
Serial.print("AdafruitIO_Group::call(...) cur_cb=0x"); // jmn
Serial.print((uint32_t)cur_cb, HEX); // jmn
Serial.println(); // jmn
if(strcmp(cur_cb->feed, d->feedName()) == 0 || cur_cb->feed == NULL) { // <===== Error occurs on this line
cur_cb->dataCallback(d);
setup complete
sending info: inout.FlounderIsIn -> 0
sending info: inout.KatelyIsIn -> 0
sending info: inout.MaryIsIn -> 0
AdafruitIO_Group::call(...) cur_cb=0xFEFEFEFE
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d3da5 PS : 0x00060030 A0 : 0x800d3e48 A1 : 0x3ffb1ed0
A2 : 0xfefefefe A3 : 0x3ffbe38c A4 : 0x3ffc43b0 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800d3da3 A9 : 0x3ffb1eb0
A10 : 0x3ffbe38c A11 : 0xfefefefe A12 : 0x00000010 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x00000008 EXCCAUSE: 0x0000001c
EXCVADDR: 0xfefefefe LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffd
Backtrace: 0x400d3da5:0x3ffb1ed0 0x400d3e45:0x3ffb1ef0 0x400d4470:0x3ffb1f40 0x400d39c6:0x3ffb1f60 0x400d2181:0x3ffb1f80 0x4013fd9e:0x3ffb1fa0
Rebooting...
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:808
load:0x40078000,len:6084
load:0x40080000,len:6696
entry 0x400802e4
Connecting to Adafruit IOAdafruitIO::connect()
Adafruit IO connected.
sending example.count-1 -> 0
sending example.count-2 -> 0
AdafruitIO_Group::call(...) cur_cb=0xFEFEFEFEGuru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
PC : 0x400d2395 PS : 0x00060e30 A0 : 0x800d2438 A1 : 0x3ffb1ed0
A2 : 0xfefefefe A3 : 0x3ffbfe40 A4 : 0x3ffc3ee0 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800d2393 A9 : 0x3ffb1eb0
A10 : 0x3ffbfe40 A11 : 0xfefefefe A12 : 0x00000010 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000000a EXCCAUSE: 0x0000001c
Backtrace: 0x400d2395:0x3ffb1ed0 0x400d2435:0x3ffb1ef0 0x400d2a60:0x3ffb1f40 0x400d1fda:0x3ffb1f60 0x400d1cc8:0x3ffb1f80 0x4013cc22:0x3ffb1fa0
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400802e4
