IDEAS: ADAFRUIT IO FEATURE SUGGESTIONS
Re: IDEAS: ADAFRUIT IO FEATURE SUGGESTIONS
by meteorkees on Wed Nov 18, 2020 2:37 pm
Hello all,
All times in the feeds and dashboard graphs, show the timestamps in AM/PM format. Is it possible to have a choice for format 24hrs or am/pm?
meteorkees
by JMJunek on Sat Dec 05, 2020 4:38 pm
It would be nice if you could have a way to allow multiple people to interact with one dashboard. Like if I set up some kind of automation or remote control of a project from my dashboard and I want another member of my team to be able to interact with it. Currently, if they have an AIO account, they can see it but they cannot hit any of the buttons or toggles.
JMJunek
by brubell on Fri Dec 11, 2020 10:01 am
JMJunek wrote:It would be nice if you could have a way to allow multiple people to interact with one dashboard. Like if I set up some kind of automation or remote control of a project from my dashboard and I want another member of my team to be able to interact with it. Currently, if they have an AIO account, they can see it but they cannot hit any of the buttons or toggles.
You need to give the people interacting with your dashboard read and write access to the feeds connected to the buttons/toggles.
brubell
by adafruitguy on Wed Dec 23, 2020 12:49 pm
Trigger that could act if a feed hasn't been seen (updated) in a set period of time [days] [hours] [minutes].
adafruitguy
by wsquared58 on Sun Jan 03, 2021 2:32 pm
Allow IO Plus dashboards to be embeddable in an iFrame.
See my attached information board for reference. This information board is created by adding modules to a Magic Mirror project. These https://magicmirror.builders/ can be seen in link.
In my case, I would put embedded IO+ Dashboard in location below NOAA/NWS Radar page which is embedded in an iFrame.
wsquared58
by wsquared58 on Sun Jan 03, 2021 3:11 pm
This is a tweak/option for two existing blocks. These would be the GAUGE block and the LINE GRAPH block.
Allow user to define colors for the high and low warning values. As someone who spent 30 years in a power plant, high and low readings are generally not colored like the gauge block option is.
Generally, both high and low are considered as out of spec and would be colored red. This does vary by instrument somewhat but as an example, you are reading outdoor temperature in a weather station and you want to know whether to wear a coat in winter, or wear shorts in summer. You might say give me a LOW RED at 45F (wear a jacket) and if temperature got above 80F throw a HIGH RED (wear shorts). The way you would use yellow typically is as a caution value.
OFF SCALE HIGH--------------------------------------------------------
RED REGION
HIGH ALARM RED--------------------------------------------------------
YELLOW REGION
HIGH WARNING YELLOW---------------------------------------------
NORMAL OPERATING RANGE NORMAL OPERATING RANGE GREEN
LOW WARNING YELLOW----------------------------------------------
YELLOW REGION
LOW ALARM RED--------------------------------------------------------
RED REGION
OFF SCALE LOW---------------------------------------------------------
wsquared58
by jwcooper on Wed Feb 24, 2021 12:47 pm
adafruitguy wrote:Trigger that could act if a feed hasn't been seen (updated) in a set period of time [days] [hours] [minutes].
We don't have this currently, but we do have a feed notification service now:
When notifications are activated, Adafruit IO will send an email to alert you if no new data has been received for your feed within the given amount of time.
You can view it on the feed page located at https://io.adafruit.com/{username}/feeds/feed-name
jwcooper
by ishwarm on Sun Feb 28, 2021 12:13 pm
It would be great to have an Itsy Bitsy board based on the nRF5340 which has a Dual-core along with an Ultra low-power radio for Bluetooth. The chip has 128 MHz + 64 MHz CPUs which would ensure that the processing for sending of Bluetooth data will not affect the performance of the loop processing. The radio current consumption for 0dBm TX is a minuscule 3.4mA and is well suited for battery-powered applications. Reference: https://www.nordicsemi.com/Products/Low ... ss/nRF5340
ishwarm
by Systembolaget on Thu Mar 11, 2021 3:14 am
As long as one can't selectively delete data points, the preselected Confirm button could be enabled to react to one's keyboard enter key.
Skärmbild 07.58.24.png (72.91 KiB) Viewed 169 times
When typing in a Block title for a new block on a new dashboard, all one's previously used titles appear in a very long list of suggestions.
Line colour and line thickness choice would be good.
Systembolaget
by wsquared58 on Sat Mar 13, 2021 2:21 pm
Allow various blocks to be reduced in size beyond their current minimum sizes. Users should be able to place more than one block tall and two blocks wide (gauge block) on the official Pi Foundation 7" screen.
wsquared58
by brubell on Mon Mar 15, 2021 9:37 am
For which block?
brubell
wsquared58 wrote:Allow various blocks to be reduced in size beyond their current minimum sizes. Users should be able to place more than one block tall and two blocks wide (gauge block) on the official Pi Foundation 7" screen.
Could you show me a picture of what a dashboard looks like on this screen? I don't have one.
brubell
by Systembolaget on Mon Mar 15, 2021 1:39 pm
For the line graphs primarily.
Systembolaget
by wsquared58 on Mon Mar 15, 2021 3:08 pm
Screen Capture
Screenshot 7 inch Pi Scree..jpg (47.04 KiB) Viewed 151 times
wsquared58
by wsquared58 on Mon Mar 15, 2021 3:10 pm
That is the minimum allowable size on the two gauge blocks and stuck trend line below and you can see it runs off bottom edge. Also, this is full screen view.
wsquared58
