Hi I am trying to display a feed from an ESP8266 - GPS on the map dashboard.
20.0000,-32.723333,152.131399,46.8
Value, Lat,Long,Alt. Ive used some samples.
Its shared here and not appearing as a point on the map.
https://io.adafruit.com/rwaski/feeds/speed
Adafruit map dashboard
- abachman
Re: Adafruit map dashboard
hi rwaski,
Are you able to share the code you're using to publish to Adafruit IO?
- adam b.
- adam b.
