Arduino stops receiving Adafruit IO data
by W0810877 on Tue Oct 16, 2018 11:33 pm
Hi. I've got an Adarfruit Feather HUZZAH ESP8266 connected to a feed in Adafruit IO. The program receives data from the feed, in this case, an integer representing the temperature. The code seems to work properly, at first.
I add data points, one by one, into the feed. Each value is interpreted and a NeoPixel display changes based on some logic. I then print out the connection status, and that ends the handleMessage method.
My problem is that after 2-7 data points, the program stops receiving data points from Adafruit IO. I've had it happen randomly after 2, 5, 7 data points. After each data point, a message is printed saying connected to Adafruit. After the last data point before it hangs, no connection status is printed.
Any ideas what could be dropping the connection? I'm using Adafruit IO Arduino library version 2.7.19.
Here's some output from my Serial Monitor:
Connecting to Adafruit IOAdafruitIO::connect()
Adafruit IO connected.
received <- 68 Previous <- 0
I'm thawing!
received <- 73 Previous <- 68
A pleasant temperature and warming!
received <- 74 Previous <- 73
received <- 78 Previous <- 74
It's hot and getting hotter!
received <- 100 Previous <- 78
received <- 62 Previous <- 100
I'm freezing!
Here's the output from the Adafruit IO monitor page.
Live Data newest data at the top
2018-10-16 20:23:23nest-temp15
2018-10-16 20:23:17nest-temp25
2018-10-16 20:22:54nest-temp62
2018-10-16 20:22:45nest-temp100
2018-10-16 20:22:34nest-temp78
2018-10-16 20:22:26nest-temp74
2018-10-16 20:22:18nest-temp73
2018-10-16 20:22:08nest-temp68
2018-10-16 20:21:46nest-temp73
Connections only available while this page is open
2018-10-16 20:28:243f7d3707-13ae-4edc-99e8-1b43d297disconnected
2018-10-16 20:23:27io-browser-10947a60disconnected
2018-10-16 20:22:023f7d3707-13ae-4edc-99e8-1b43d297connected
2018-10-16 20:21:3105893bf3-2a9c-4cd0-b7b0-b4a5133ddisconnected
2018-10-16 20:21:06io-browser-10947a60connected
Thanks much!
W0810877
Re: Arduino stops receiving Adafruit IO data
by brubell on Wed Oct 17, 2018 10:33 am
It doesn't look like (from the monitor) that you're getting timed out of IO.
Can you post your code?
brubell
by W0810877 on Mon Oct 22, 2018 10:46 pm
Attached.
Project2.ino
(4.36 KiB) Downloaded 12 times
W0810877
