Feather M0 does not connect with Adafruit IO
by ingenieriamicrotec on Tue Oct 23, 2018 5:38 pm
Good afternoon!
I am trying to run the digital out example for Adafruit IO with my Feather M0, but it never connects!
On my Arduino IDE's Serial Monitor I get:
Connecting to Adafruit IOAdafruitIO::connect()
... till inf and it never connects :(
Please help!
Thank you!
ingenieriamicrotec
Re: Feather M0 does not connect with Adafruit IO
by oesterle on Tue Oct 23, 2018 11:07 pm
Hi, Isaac!
Which Feather M0 are you using? Is it internet capable, or are you using an internet-capable FeatherWing? (Wi-Fi, cellular (FONA), or Ethernet?)
Cheers,
Eric
oesterle
by ingenieriamicrotec on Wed Oct 24, 2018 4:35 pm
Feather M0 WiFi ATWINC1500
This one:
https://www.adafruit.com/product/3010
ingenieriamicrotec
by abachman on Wed Oct 24, 2018 4:46 pm
Hi isaac,
Two things to check are that you have the correct Adafruit IO keys in your sketch (pretty easy to check) and that you have up to date SSL certificates for io.adafruit.com on your device (more complicated to check). You can find the guide for that here.
The SSL certificate problem in particular is hard to diagnose without going through the whole update process, so you might as well give that a try if you haven't done it yet.
- Adam B.
abachman
by ingenieriamicrotec on Mon Oct 29, 2018 9:25 am
Thank you oesterle and abachman!
I updated the ssl certificates and now it works!
Thank you so much!
ingenieriamicrotec
