Unable to install Adafruit-IO on Pi3
by sdb614 on Wed Oct 31, 2018 7:36 pm
I get the error below when I try installing the Adafruit IO package on my Raspberry Pi 3. All the other packages installed just fine. I did all the previous steps successfully including apt-get update and apt-get upgrade. I'm a complete novice just blindly following instructions from here https://learn.adafruit.com/adafruit-io-basics-digital-output/python-setup and have barely used the Pi so I don't know how I could have messed that up.
What am I doing wrong?
Here is some more info on my device:
    pip 1.5.6 from /usr/lib/python3/dist-packages (python 3.4)
    debian version 8.0
pi@raspberrypi:~ $ sudo pip3 install adafruit-io
Downloading/unpacking adafruit-io
  Downloading adafruit-io-2.0.17.tar.gz (41kB): 41kB downloaded
  Running setup.py (path:/tmp/pip-build-3j6sk77s/adafruit-io/setup.py) egg_info for package adafruit-io
    version:  2.0.17
      File "<string>", line 17, in <module>
      File "/tmp/pip-build-3j6sk77s/adafruit-io/setup.py", line 68, in <module>
        classifiers      = classifiers
      File "/usr/local/lib/python3.4/dist-packages/setuptools/__init__.py", line 140, in setup
        return distutils.core.setup(**attrs)
      File "/usr/lib/python3.4/distutils/core.py", line 148, in setup
        dist.run_commands()
      File "/usr/lib/python3.4/distutils/dist.py", line 955, in run_commands
        self.run_command(cmd)
      File "/usr/lib/python3.4/distutils/dist.py", line 974, in run_command
        cmd_obj.run()
      File "<string>", line 14, in replacement_run
      File "/usr/local/lib/python3.4/dist-packages/setuptools/command/egg_info.py", line 614, in write_pkg_info
        metadata.write_pkg_info(cmd.egg_info)
      File "/usr/lib/python3.4/distutils/dist.py", line 1108, in write_pkg_info
        self.write_pkg_file(pkg_info)
      File "/usr/local/lib/python3.4/dist-packages/setuptools/dist.py", line 91, in write_pkg_file
        long_desc = rfc822_escape(self.get_long_description())
      File "/usr/lib/python3.4/distutils/util.py", line 470, in rfc822_escape
        lines = header.split('\n')
    TypeError: Type str doesn't support the buffer API
    Complete output from command python setup.py egg_info:
    version:  2.0.17
running egg_info
creating pip-egg-info/adafruit_io.egg-info
writing pip-egg-info/adafruit_io.egg-info/PKG-INFO
    dist.run_commands()
    cmd_obj.run()
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-3j6sk77s/adafruit-io
Storing debug log for failure in /root/.pip/pip.log
I tried installing a different way.
pi@raspberrypi:~/io-client-python $ sudo python3 setup.py install
version:  2.0.17
running install
running bdist_egg
running egg_info
writing top-level names to adafruit_io.egg-info/top_level.txt
writing adafruit_io.egg-info/PKG-INFO
  File "setup.py", line 68, in <module>
    dist.run_commands()
    cmd_obj.run()
  File "/usr/local/lib/python3.4/dist-packages/setuptools/command/install.py", line 67, in run
    self.do_egg_install()
  File "/usr/local/lib/python3.4/dist-packages/setuptools/command/install.py", line 109, in do_egg_install
    self.run_command('bdist_egg')
  File "/usr/lib/python3.4/distutils/cmd.py", line 313, in run_command
    self.distribution.run_command(command)
    cmd_obj.run()
  File "/usr/local/lib/python3.4/dist-packages/setuptools/command/bdist_egg.py", line 163, in run
    self.run_command("egg_info")
    cmd_obj.run()
  File "/usr/local/lib/python3.4/dist-packages/setuptools/command/egg_info.py", line 289, in run
    writer(self, ep.name, os.path.join(self.egg_info, ep.name))
When I just run setup.py without "install" after, it gives me this:
pi@raspberrypi:~/io-client-python $ python3 setup.py
version:  2.0.17
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
   or: setup.py --help [cmd1 cmd2 ...]
   or: setup.py --help-commands
   or: setup.py cmd --help
error: no commands supplied
Why is this giving an error? Thanks.
sdb614
Re: Unable to install Adafruit-IO on Pi3
by adafruit2 on Mon Nov 05, 2018 11:30 pm
what OS/version are you running? it may matter!
adafruit2
Site Admin
by sdb614 on Tue Nov 06, 2018 9:16 am
I am running Raspbian Version 8 on a Raspberry Pi 3 Model B. Is this out-of-date?
Here are the details:
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
sdb614
by brubell on Tue Nov 06, 2018 10:04 am
Could you try updating setuptools:
easy_install -U setuptools
or
pip3 install setuptools --upgrade
Then, try re-running the installer:
brubell
by sdb614 on Tue Nov 06, 2018 7:33 pm
Unfortunately, neither work. Setuptools is already installed.
pi@raspberrypi:~ $ sudo pip3 install setuptools --upgrade
Requirement already up-to-date: setuptools in /usr/local/lib/python3.4/dist-packages
Cleaning up...
When I try installing adafruit-io again:
  Running setup.py (path:/tmp/pip-build-zt16aeux/adafruit-io/setup.py) egg_info for package adafruit-io
    version:  2.0.17
      File "/tmp/pip-build-zt16aeux/adafruit-io/setup.py", line 68, in <module>
        dist.run_commands()
        cmd_obj.run()
    version:  2.0.17
running egg_info
writing requirements to pip-egg-info/adafruit_io.egg-info/requires.txt
    dist.run_commands()
    cmd_obj.run()
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-zt16aeux/adafruit-io
sdb614
by brubell on Thu Nov 08, 2018 10:45 am
Could you try updating your Python installation to 3.5? I've been attempting to replicate this on my end using your setup without success.
brubell
by sdb614 on Thu Nov 08, 2018 7:42 pm
I'm running Python 3.4. I'm finding a lot of different ways of updating Python. Can you post a link that is your preferred method? Does it need to be 3.5 or can it be something even later?
Python 3.5 comes with Raspbian Stretch right? I'm running Jessie. I can update by installing Stretch?
sdb614
by adafruit2 on Thu Nov 08, 2018 11:04 pm
yeah you should really update/upgrade!
adafruit2
Site Admin
