mqtt.readSubscription(5000)
by erikdw on Wed Nov 07, 2018 9:28 am
I'm using "mqtt.readSubscription(5000)" in my script and work fine to receive onoff button information.
But the problem is that my main loop is waiting 5sec and do nothing.
So reading a local switch on a pin for example give problems. I must push more then 5 sec before he read the status.
Is there a solution ?
erikdw
Re: mqtt.readSubscription(5000)
by brubell on Thu Nov 08, 2018 10:46 am
Could you post the complete code or snippet that is giving you trouble?
What version of the MQTT Library are you using?
brubell
by erikdw on Thu Nov 08, 2018 12:30 pm
this is the complete part to check the onoff switch :
// this is our 'wait for incoming subscription packets' busy subloop
Adafruit_MQTT_Subscribe *subscription;
while (subscription = mqtt.readSubscription(5000)) {
// we only care about the lamp events
if (subscription == &lamp) {
// convert mqtt ascii payload to int
char *value = (char *)lamp.lastread;
Serial.print(F("Received: "));
Serial.println(value);
// Apply message to lamp
String message = String(value);
message.trim();
if (message == "ON") {digitalWrite(lamp_pin, HIGH);}
if (message == "OFF") {digitalWrite(lamp_pin, LOW);}
I'm not at home, I can't see the lib version
erikdw
by erikdw on Mon Nov 12, 2018 5:20 am
the adafruit MQTT lib is version 0.20.3
erikdw
