'AdafruitIO_WiFi' does not name a type
by Sethi on Sun Dec 02, 2018 11:13 am
I install the adafruit IOs libraries and then I load the adafruitio_08_analog_in. When I try to compile the code it fires 'AdafruitIO_WiFi' does not name a type error.
What can I do?
Sethi
Re: 'AdafruitIO_WiFi' does not name a type
by brubell on Tue Dec 04, 2018 10:54 am
Do you have the three required Arduino libraries installed: Adafruit IO Arduino, Adafruit MQTT, and ArduinoHttpClient?
brubell
by prsveloso on Fri Dec 21, 2018 3:45 pm
I´m experiencing the same problem. I have the required Arduino libraries installed.
I´m using Arduino IDE 1.8.8
Can´t see where's the problem.
Any suggestions?
Thanks in advance.
I'm sorry but I was compiling to Arduino Uno.
But, if I change to Huzzah ESP8266 I get another error.
Please see the log.
Log.txt
(86.63 KiB) Downloaded 10 times
prsveloso
by prsveloso on Sat Dec 22, 2018 11:22 am
I believe that I've found the problem.
If I downgrade, in Boards Manager, the esp8266 v. 2.5.0-beta2 to v2.4.2 it compiles without any problem.
Hope this helps!
prsveloso
