MCP9808 & Ada io
MCP9808 & Ada io
by morwic on Fri Dec 28, 2018 1:13 am
Does anyone have any idea what a working config would be for a mcp9808 on a esp8266 to send data to a single ada io feed ? I've tried the hack on the dht22 config from the ada learn doc's, but I have no luck :(
Thank You
morwic
Re: MCP9808 & Ada io
by brubell on Fri Dec 28, 2018 11:58 am
The MCP9808 is more similar to the environmental logger project (https://learn.adafruit.com/adafruit-io- ... duino-code) than the DHT22 library.
Post your code, what you got as an output in the Serial Monitor, and I'll help you out.
brubell
by morwic on Fri Dec 28, 2018 12:08 pm
Thank you I'm not a coder and kinda blind... I know it's a great combo LUL. I've been on this for 3 days :( with no joy, thank you so much for your help
  Adafruit ESP8266 Sensor Module
  Must use ESP8266 Arduino from:
    https://github.com/esp8266/Arduino
  Works great with Adafruit's Huzzah ESP board:
  ----> https://www.adafruit.com/product/2471
  products from Adafruit!
  Written by Tony DiCola for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
// Libraries
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
//#include "DHT.h"
//#include <TMP36.h>
#include "Adafruit_MCP9808.h"
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
//TMP36 myTMP36(A0, 3.3);
//DHT 11 sensor
//#define DHTPIN 5
//#define DHTTYPE DHT11
// WiFi parameters
#define WLAN_SSID       "53piritesandonejugofrum"
#define WLAN_PASS       "youMomlikesmyada"
// Adafruit IO
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "knock knock"
#define AIO_KEY         "no one home"  // Obtained from account info on io.adafruit.com
// DHT sensor
//DHT dht(DHTPIN, DHTTYPE, 15);
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// Setup feeds for temperature & humidity
Adafruit_MQTT_Publish temperature = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/housetemp");
// Adafruit_MQTT_Publish humidity = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/humidity");
/*************************** Sketch Code ************************************/
  // Make sure the sensor is found, you can also pass in a different i2c
  // address with tempsensor.begin(0x19) for example
  if (!tempsensor.begin()) {
    Serial.println("Couldn't find MCP9808!");
    while (1);
  // Init sensor
//  dht.begin();
  Serial.begin(115200);
  Serial.println(F("Adafruit IO Example"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  delay(10);
  Serial.print(F("Connecting to "));
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(F("."));
  Serial.println();
  Serial.println(F("WiFi connected"));
  Serial.println(F("IP address: "));
  Serial.println(WiFi.localIP());
  // connect to adafruit io
 // connect();
    //Serial.println("wake up MCP9808.... "); // wake up MSP9808 - power consumption ~200 mikro Ampere
  //tempsensor.wake();   // wake up, ready to read!
  // Read and print out the temperature, then convert to *F
  float c = tempsensor.readTempC();
  float f = c * 9.0 / 5.0 + 32;
  Serial.print("Temp: "); Serial.print(c); Serial.print("*C\t");
  Serial.print(f); Serial.println("*F");
  //Serial.println("Shutdown MCP9808.... ");
  //tempsensor.shutdown(); // shutdown MSP9808 - power consumption ~0.1 mikro Ampere
  delay(1000);
  // ping adafruit io a few times to make sure we remain connected
  if(! mqtt.ping(3)) {
    // reconnect to adafruit io
    if(! mqtt.connected())
      connect();
  // Grab the current state of the sensor
//  int humidity_data = (int)dht.readHumidity();
  int temperature_data = (int)Adafruit_MCP9808.getTempF();
  // By default, the temperature report is in Celsius, for Fahrenheit uncomment
  //    following line.
   temperature_data = temperature_data*(9.0/5.0) -48.0;
  // Publish data
//  if (! temperature.publish(temperature_data))
    Serial.println(F("Failed to publish temperature"));
  else
    Serial.println(F("Temperature published!"));
//  if (! humidity.publish(humidity_data))
    Serial.println(F("Failed to publish humidity"));
//  else
//    Serial.println(F("Humidity published!"));
  // Repeat every 20 seconds
  delay(10000);
    //create a variable and store the current temperature in
  //celius in it using the getTempC function
  float celsius = myTMP36.getTempC();
  //fahrenheit in it using the getTempF function
  float fahrenheit = myTMP36.getTempF();
  //Print the data to the Serial monitor
  Serial.print("Celsius: ");
  Serial.print(celsius);
  Serial.print(" Fahrenheit: ");
  Serial.println(fahrenheit);
  delay(5000);
// connect to adafruit io via MQTT
void connect() {
  Serial.print(F("Connecting to Adafruit IO... "));
  int8_t ret;
  while ((ret = mqtt.connect()) != 0) {
    switch (ret) {
      case 1: Serial.println(F("Wrong protocol")); break;
      case 2: Serial.println(F("ID rejected")); break;
      case 3: Serial.println(F("Server unavail")); break;
      case 4: Serial.println(F("Bad user/pass")); break;
      case 5: Serial.println(F("Not authed")); break;
      case 6: Serial.println(F("Failed to subscribe")); break;
      default: Serial.println(F("Connection failed")); break;
    if(ret >= 0)
      mqtt.disconnect();
    Serial.println(F("Retrying connection..."));
    delay(30000);
  Serial.println(F("Adafruit IO Connected!"));
Reason: added code box
morwic
by morwic on Wed Jan 02, 2019 2:38 pm
any help here ? :(
morwic
by morwic on Mon Jan 07, 2019 12:02 pm
Any Help yet from Ada ?
morwic
by abachman on Mon Jan 07, 2019 1:38 pm
After the `delay(1000);` line in your main loop function you have an extra closing curly brace "}", which means your loop is followed by a bunch of extra code that is never executed.
So in your project you have this:
  delay(1000);
      connect();
  //    following line.
  // Publish data
  else
//  else
  delay(10000);
  delay(5000);
But the actual code that runs looks like this:
  delay(1000);
abachman
by morwic on Mon Jan 07, 2019 5:47 pm
ahh thank you so much let me try this and see if it will report meow ti ada io :)
morwic
