Example temp/Humidity script
by chorlton2080 on Sun Dec 30, 2018 12:12 pm
Hello
I'm using the example Adafruit IO code in the Arduino library and am having problems reflashing the Arduino code to my Huzzah after changing the WiFi password. It has previously worked. The error from the Arduino IDE is as follows:
Arduino: 1.8.1 (Windows 10), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp: In member function 'virtual bool Adafruit_MQTT_Client::sendPacket(uint8_t*, uint16_t)':
C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: error: no matching function for call to 'min(uint16_t&, int)'
       uint16_t sendlen = min(len, 250);
C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note: candidates are:
In file included from c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:62:0,
                 from C:\Users\Stuart\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Arduino.h:254,
                 from C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.h:25,
                 from C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.h:26,
                 from C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:22:
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note: template<class _Tp, class _Compare> _Tp std::min(std::initializer_list<_Tp>, _Compare)
     min(initializer_list<_Tp> __l, _Compare __comp)
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note:   template argument deduction/substitution failed:
C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note:   mismatched types 'std::initializer_list<_Tp>' and 'short unsigned int'
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note: template<class _Tp> _Tp std::min(std::initializer_list<_Tp>)
     min(initializer_list<_Tp> __l)
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note:   template argument deduction/substitution failed:
In file included from c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:61:0,
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note: template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note:   template argument deduction/substitution failed:
C:\Users\Stuart\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT_Client.cpp:84:38: note:   deduced conflicting types for parameter 'const _Tp' ('short unsigned int' and 'int')
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)
     min(const _Tp& __a, const _Tp& __b)
c:\users\stuart\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note:   template argument deduction/substitution failed:
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
Does anyone have any ideas?
chorlton2080
Re: Example temp/Humidity script
by adafruit_support_carter on Fri Jan 04, 2019 2:44 pm
Did you also update the ESP8266 BSP by any chance? What version are you currently using?
