Disconnected from Adafruit IO
by D1ZZY on Mon Dec 31, 2018 7:00 pm
I am using a MKR1000 and I have been trying to follow https://learn.adafruit.com/adafruit-io-basics-servo - I'm currently just trying to test it and every time it gives me an infinite "Disconnected from Adafruit IO" on the serial monitor. I've gone through it multiple times to see if I've made a mistake and nothing seems to change the outcome. I've tested 2 different WiFi sources so that is not the problem and I tested the example from the WiFi101 library and it works perfectly. I've also reset my IO Key and that did nothing.
D1ZZY
Re: Disconnected from Adafruit IO
by D1ZZY on Tue Jan 01, 2019 3:37 pm
I solved it by following this: https://learn.adafruit.com/adafruit-fea ... rtificates - just had to add the adafruit io domain.
D1ZZY
cron
