Feeds not creating when topic arriving
by zachwatts94 on Fri Jan 04, 2019 12:20 am
I'm sending data to adafruit from an esp8266. Except for my uptime feed, none of the feeds are being created as expected. I can see data showing up in the "live data" section and it even has the group name (default.<feed_name>) but no feed is created and the data is not stored. I even tried creating a feed manually that matches the feed being sent by my board, but no data was updated.
zachwatts94
Re: Feeds not creating when topic arriving
by franklin97355 on Fri Jan 04, 2019 12:27 am
Have you tried any of the example programs?
franklin97355
by brubell on Fri Jan 04, 2019 11:24 am
zachwatts94 wrote:I'm sending data to adafruit from an esp8266. Except for my uptime feed, none of the feeds are being created as expected. I can see data showing up in the "live data" section and it even has the group name (default.<feed_name>) but no feed is created and the data is not stored. I even tried creating a feed manually that matches the feed being sent by my board, but no data was updated.
If it's showing up on live-data, there's a possibility of a feed/key mismatch.
Make sure your feed key in the sketch is lower-case.
i,e:
AdafruitIO_Feed *orientationfeed = io.feed("orientationfeed");
not:
AdafruitIO_Feed *OrientationFeed = io.feed("OrientationFeed");
brubell
