disconect from adafruit io
by fmeylink on Tue Jan 08, 2019 7:07 pm
i got disconnected after a minute from the adafruit io.
i made a verbose debug that is below:
AdafruitIO::connect()
[D][WiFiGeneric.cpp:265] _eventCallback(): Event: 2 - STA_START
.......[D][WiFiGeneric.cpp:265] _eventCallback(): Event: 4 - STA_CONNECTED
[D][WiFiGeneric.cpp:265] _eventCallback(): Event: 7 - STA_GOT_IP
[V][ssl_client.cpp:48] start_ssl_client(): Free heap before TLS 147684
[V][ssl_client.cpp:50] start_ssl_client(): Starting socket
[V][ssl_client.cpp:86] start_ssl_client(): Seeding the random number generator
[V][ssl_client.cpp:95] start_ssl_client(): Setting up the SSL/TLS structure...
[I][ssl_client.cpp:119] start_ssl_client(): WARNING: Use certificates for a more secure communication!
[V][ssl_client.cpp:143] start_ssl_client(): Setting hostname for TLS session...
[V][ssl_client.cpp:158] start_ssl_client(): Performing the SSL/TLS handshake...
[V][ssl_client.cpp:177] start_ssl_client(): Verifying peer X.509 certificate...
[V][ssl_client.cpp:186] start_ssl_client(): Certificate verified.
[V][ssl_client.cpp:201] start_ssl_client(): Free heap after TLS 104036
[V][ssl_client.cpp:240] send_ssl_data(): Writing HTTP request...
Adafruit IO connected.
AIN0: 4398
AIN1: 4444
AIN2: 5174
AIN3: 4401
AIN0: 4401
AIN1: 4444
AIN2: 5165
AIN3: 4401
after a minuteL:
[E][ssl_client.cpp:28] handle_error(): UNKNOWN ERROR CODE (004E)
[E][ssl_client.cpp:30] handle_error(): MbedTLS message code: -78
[V][ssl_client.cpp:209] stop_ssl_socket(): Cleaning SSL connection.
[V][ssl_client.cpp:48] start_ssl_client(): Free heap before TLS 118708
[E][ssl_client.cpp:80] start_ssl_client(): Connect to Server failed!
[E][WiFiClientSecure.cpp:107] connect(): lwip_connect_r: 113
[V][ssl_client.cpp:48] start_ssl_client(): Free heap before TLS 144392
[D][WiFiGeneric.cpp:265] _eventCallback(): Event: 5 - STA_DISCONNECTED
[W][WiFiGeneric.cpp:270] _eventCallback(): Reason: 7 - NOT_ASSOCED
it looks like the certificate is not ok, how do i fix the certificate thing ?
i have a esp32 feather used the examples from adafruit io even the examples are not working.
any thoughts ??
fmeylink
Re: disconect from adafruit io
by franklin97355 on Tue Jan 08, 2019 10:03 pm
franklin97355
by fmeylink on Wed Jan 09, 2019 4:35 am
tank you for the sugestion.
I have a feather esp32, this solution is for other boards.
fmeylink
