No Feed Data received
by frommy69 on Wed Jan 09, 2019 2:04 pm
As my first attempt today I implemented the LED example
(https://learn.adafruit.com/adafruit-io- ... tal-output)
project with the Hazzah Feather ESP. After the instructions he uploaded the program properly and in the serial monitor he got the message that he is connected. But now I have the problem that the LED doesn't come on when I operate the dashboard. What am I doing wrong? It also doesn't show me in the serial monitor that it has received data (function: handleMessage(AdafruitIO_Data *data)). I am a beginner and don't know what to do now. Thanks in advance for the feedback.
frommy69
Re: No Feed Data received
by franklin97355 on Wed Jan 09, 2019 3:56 pm
Did you start at the beginning of the lessons or are you jumping into the middle?
franklin97355
by frommy69 on Wed Jan 09, 2019 4:15 pm
Hi, thanks for the quick feedback. Yes, I've worked through it all and put it clean. Feeds, dashboard, the connection. I ask me if I need to share any port at the router, so the AIO can even send data from outside?
frommy69
by frommy69 on Wed Jan 09, 2019 4:29 pm
Overview Compiling
frommy69
by frommy69 on Wed Jan 09, 2019 5:36 pm
I had created my own feed group. It doesn't work there. Now I created the feed in the default area. There it went....
Assume that it is a restriction of the test environment.
Thank you for helping me.
frommy69
by abachman on Wed Jan 09, 2019 6:56 pm
Hi frommy,
I'm glad you got it working!
The best way to make sure your sketch is subscribed to the correct feed is to use the key that Adafruit IO shows you when you create the feed. If you made the feed in a group, for example, you should see something like this on io.adafruit.com:
Screen Shot 2019-01-09 at 5.29.39 PM.png (13.15 KiB) Viewed 123 times
Feeds in the default group may sometimes work when you subscribe to their name, but it's always safer to use the feed key when referring to the feed in code.
- adam b.
abachman
