error: espcomm_upload_mem failed
by jhbowling on Thu Jan 10, 2019 8:44 pm
I have an Adafruit HUZZAH ESP8266 Breakout PID: 2471 that I can't seem to program. I have it powered with an external power source with common ground and when I try to upload I get:
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
warning: espcomm_sync failed
error: espcomm_open failed
I am not the type of person who normally posts...instead I scour the forums and eventually figure things out, but this one has me stumped. I have tried a lot of different things but nothing has worked.
If I wire #0 to ground while uploading, I get this:
Uploading 294080 bytes from /tmp/arduino_build_253614/Blink.ino.bin to flash at 0x00000000
erasing flash
size: 047cc0 address: 000000
first_sector_index: 0
total_sector_count: 72
head_sector_count: 16
adjusted_sector_count: 56
erase_size: 038000
setting timeout 15000
setting timeout 1000
espcomm_send_command: receiving 2 bytes of data
writing flash
serialport_receive_C0: 00 instead of C0
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
serialport_receive_C0: 02 instead of C0
closing bootloader
In either case the red light remains dimly lit.
jhbowling
Re: error: espcomm_upload_mem failed
by jhbowling on Sat Jan 12, 2019 1:49 pm
I am now able to program the Huzzah.
I have a dual boot machine (Ubuntu 16.04/Windows 10) and I decided to give Windows a try. Installed Arduino IDE, compiled, and now I'm able to upload by connecting #0 to ground. If I reboot into Ubuntu the exact same hookup is not working. Very strange.
jhbowling
by adafruit_support_carter on Thu Jan 17, 2019 2:50 pm
What are you using to connect the breakout to the PC?
by jhbowling on Sat Jan 19, 2019 12:28 pm
This product:
https://www.sparkfun.com/products/11301
I also tried another cable...same result.
jhbowling
