Node Red and MQTT
Node Red and MQTT
by gadjet on Mon Jan 21, 2019 7:04 pm
I've just created an account with you and would like to use Node Red to post data.
I cannot use the service as I do other services I've used as the server just disconnects, I understand that it is because the message I send is not formed correctly.
Could you give an example of how the topic should be set up in the MQTT node, I've tried to follow your FAQ but I cannot get the format right because it keeps disconnecting.
Thanks for you help.
gadjet
Re: Node Red and MQTT
by brubell on Wed Jan 23, 2019 7:21 pm
Can you provide some output from NODE RED?
Which FAQ page were you following, what's your configuration in NODE RED?
brubell
by gadjet on Thu Jan 24, 2019 2:28 am
brubell wrote:Can you provide some output from NODE RED?
Thanks, I think I've sorted it, in the example user/feeds/feedname I was replacing "feeds" with my dashboard name, once I figured out it should stay as feeds it started to work although it looks like only some values got through to the dashboard.
gadjet
