Publish to single MQTT topic to update multiple feeds
by sensmaster on Tue Jan 29, 2019 6:04 am
Hi guys,
As I understand currently the Adafruit IO generate 1 topic for each feed. Is it possible to publish data to a single MQTT topic with JSON formatted payload, and the JSON formatted payload has all the feeds data.
Thanks for your time.
sensmaster
Re: Publish to single MQTT topic to update multiple feeds
by abachman on Tue Jan 29, 2019 6:36 pm
Hi sensmaster,
The Groups API can do that. We use it internally in the Adafruit IO Arduino and I've added documentation to our primary MQTT documentation spot: https://learn.adafruit.com/welcome-to-a ... entation-2.
Put all the feeds you want to publish to at the same time in a group together and then MQTT publish to {username}/groups/{group_key} with the payload format:
  "feeds": {
    "key-1": "value 1",
    "key-2": "value 2",
    "key-3": "value 3"
  "location": {
    "lat": 1.0,
    "lon": 2.0,
    "ele": 3.0
Where "key-1", etc. are the feed keys you want to publish to. The location object is optional and you only have to include the feeds you want to update.
You can also subscribe to the group MQTT topic if you want to monitor all the feeds in a group from a single MQTT subscription.
- adam b.
abachman
by profhuster on Fri Mar 15, 2019 11:39 am
How would that be done in python?
The documentation and the examples I have found in io.adafruit.com and learn.adafruit.com do not mention groups very much. I did find https://learn.adafruit.com/welcome-to-adafruit-io/mqtt-api-documentation-2, but it would be nice to have a python example.
Also, key for feeds in a group, getting the key is hard to figure out.. For example I made a group something like
MyRoom0
with a feed
myroom0_temp
. In the Feed display the Name is truncated as
myroom0.myroom...
. When I click on the feed, then Feed Info I see the feed is named
advlab0-temp
and the URL is
https://io.adafruit.com/profhuster/feeds/advlab0.advlab0-temp
profhuster
