possible to subscribe with Rest API?
- sketchy
I've used mqtt in the past. I'm starting a project in Flutter. While there is a 3rd party mqtt client, it is not clear to me how robust it is. So I was looking into using the REST client. Is it possible to subscribe to a feed's changes using the REST API? From the docs, I am assuming no. But wanted to check. Thank you.
- brubell
- Learn User Page
Re: possible to subscribe with Rest API?
MQTT will update when a feed updates (on_message), but the API client will not. To get around this, you may want to save the feed's value and poll, check if the the new received value is different.
- sketchy
Thank you very much for the reply. I thought polling was the answer. This would probably work fine. With that said, I'm exploring mostly for the learning - using mqttt to Adafruit.io from a flutter/dart app.
