How to Remove Data Label?
by gfvalvo on Tue Feb 12, 2019 8:32 am
Hi. How do I get rid of this data label that shows up every time I mouse over a Line Chart on the Dashboard?
gfvalvo
Re: How to Remove Data Label?
by brubell on Tue Feb 12, 2019 10:42 am
This can not be removed - the "key" on mouseover is part of the line chart block. It's used to show data at certain points, and it supports showing more than one feed's data at a time along with the color code.
If you would like to suggest making this optional - post up on the IO suggestion thread: viewtopic.php?f=56&t=130408
brubell
by gfvalvo on Tue Feb 12, 2019 11:35 am
Thanks, I can see this being a useful feature. But, it should go away after the mouse is moved from the Line Chart area.
gfvalvo
by abachman on Tue Feb 12, 2019 5:52 pm
Hi gfvalvo,
The hover text should disappear when your cursor leaves the line chart. What browser / kind of device are you using?
- Adam
abachman
by gfvalvo on Tue Feb 12, 2019 6:40 pm
abachman wrote:The hover text should disappear when your cursor leaves the line chart. What browser / kind of device are you using?
Thanks for the reply, but that's not how it's working for me. Once the text is "activated" by mousing over the chart, it stays even if I move the mouse away. Behavior is the same for both Chrome and IE on a Win7 and a Win10 machine.
gfvalvo
by ShelM on Wed Feb 13, 2019 3:21 am
I need to chime in also. Though it is lovely to have the hover text, please add my voice to those who wish it would go away when the cursor is no longer over the chart box. Once it's turned on by moving the cursor over the box, it stays on regardless of how far away I move the cursor.
I use Chrome Version 71.0.3578.98 (Official Build) (64-bit) on Windows 7.
[EDIT] On further examination, I see that the place where the popup won't go away is in the dashboard view, and not in the feed view. Feed view good, dashboard view bad. 8^)
Bests,
...ShelM
ShelM
by gfvalvo on Thu Feb 14, 2019 11:43 pm
Well, for whatever reason, it's now working like I'd prefer on the Dashboard. As soon as you move the mouse away from the Line Chart, the moving marker and label box go away. Don't know why it's working this way for me now, but I'm happy.
gfvalvo
by abachman on Fri Feb 15, 2019 10:50 am
Hi all,
We deployed an update that fixed the non-disappearing hover label, but we lost the combined data in the label. So it'll go away, but you have to read each line in the chart separately.
We're currently exploring other charting libraries :P
- adam b.
abachman
by ShelM on Fri Feb 15, 2019 8:36 pm
Yay! Thanks Adam.
ShelM
by gfvalvo on Sat Feb 16, 2019 9:23 am
Indeed, Thanks!
gfvalvo
