Cannot make IO Publish example to work with ESP32
by grlind on Thu Feb 21, 2019 12:35 am
I am trying the basic Adafruit IO publish example to work...
I updated the network and SSID/Network and keys for IO
Adafruit IO Publish Example error messages... I have read that I need to revert the Http library? Not completely sure how to fix?
In file included from C:\Users\Gregg\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_ESP32.h:18:0,
from C:\Users\Gregg\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO_WiFi.h:27,
from sketch\config.h:21,
from C:\Users\Gregg\Documents\Arduino\ESP32adafruitio_00_publish\ESP32adafruitio_00_publish.ino:18:
C:\Users\Gregg\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO.h:23:31: fatal error: ArduinoHttpClient.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board NodeMCU-32S.
grlind
Re: Cannot make IO Publish example to work with ESP32
by brubell on Thu Feb 21, 2019 11:59 am
It doesn't look like you installed the Arduino HTTPClient.
To use Adafruit IO Arduino, you'll need to install the following libraries: Adafruit Arduino, Adafruit MQTT, and Arduino HTTPClient
brubell
by grlind on Fri Feb 22, 2019 12:15 am
thank you got it...
grlind
