Sending multiple sensor in JSON via MQTT
by Jam3sn811 on Mon Mar 25, 2019 6:03 pm
Hi there,
I'm using JSON to send multiple sensor readings in a single publish. I've followed the docs, nesting the object of sensors in "value" but AdafruitIO doesn't seem to make use of the sensors.
Here's the JSON that's published:
{"value":{"moisture":7,"temperature":20.22,"humidity":45.60449}}
In the feed the value is
Is there any way I can make use of all 3 for some fancy graphs or is this beyond AdafruitIO's capabilities?
Jam3sn811
Re: Sending multiple sensor in JSON via MQTT
by brubell on Tue Mar 26, 2019 9:44 am
Jam3sn811 wrote:Is there any way I can make use of all 3 for some fancy graphs or is this beyond AdafruitIO's capabilities?
Nothing currently, graphs support an individual feed value (and not splitting a feed into multiple values).
brubell
by Jam3sn811 on Tue Mar 26, 2019 12:20 pm
Okay thanks!
Jam3sn811
