IO Basics: Digital Output Project (works on 2.4 GHz, but not
by wetblanket on Tue Apr 02, 2019 8:24 am
I made a project based on the Adafruit IO Basics: Digital Output code, to turn a coffeemaker on and off. It worked fine for ages, when my wifi was set to 2.4 GHz, but when I changed the frequency, suddenly the Huzzah seems unable to connect to the wifi, and the relay powerstrip won't turn on/off anymore. I tried looking through the code, but didn't see anything about wifi frequency in it (just wifi name, password).
I'm not sure how to fix this. Any ideas?
wetblanket
Re: IO Basics: Digital Output Project (works on 2.4 GHz, but
by brubell on Tue Apr 02, 2019 1:11 pm
If you're using the HUZZAH ESP8266, you can not use a 5GHz network with it. The ESP8266 operates on 2.4GHz.
If your router supports it in settings - you can set up your network as a dual-band network. Alternatively, you can create a 2.4GHz network and a 5GHz network with different SSIDs.
brubell
by wetblanket on Tue Apr 02, 2019 4:45 pm
Oh, ok. Yeah, I'm using a HUZZAH ESP8266.
Thanks. I'll see if I can do one of those.
wetblanket
