Can't install Adafruit IO library to PyPortal
by MakeOneUp on Wed Apr 03, 2019 6:11 pm
I'm not able to install the Adafruit IO library to my PyPortal. Trying to use pip installed the library to my computer instead of my PyPortal. Using pip with --install-option and --prefix checked for requirements on my computer too (thus not installing anything.) I then tried downloading the git repository but the python setup.py install command didn't work. Any suggestions?
MakeOneUp
Re: Can't install Adafruit IO library to PyPortal
by brubell on Thu Apr 04, 2019 2:58 pm
Hi MakeOneUp,
You can not use pip to install the CircuitPython Adafruit IO library to your PyPortal.
First, try connecting your PyPortal to the internet: https://learn.adafruit.com/adafruit-pyp ... -file-15-1
Once it's connected, you can install the Adafruit IO library by following the instructions listed here: https://learn.adafruit.com/iot-pyportal ... lation-3-1
brubell
by MakeOneUp on Thu Apr 04, 2019 7:49 pm
Thanks. I tried downloading the circuitplayground version of the repository, but python setup.py install still didn't work I figured out to use the library bundle though, and it worked. Thanks!
MakeOneUp
