Wants To Know About trigger
by jay_raval on Wed Apr 10, 2019 1:50 pm
I have two feeds 1)Motor feed so by Switch i can turn it on or off.2) Temperature feed which shows the real time temperature.Now i wants to turn on motor if temperature is greater than 27.Can i do it by trigger?How?
also it check motor feed so if motor is on and Temp>27 do nothing,and if motor is off than it turns on.
jay_raval
Re: Wants To Know About trigger
by brubell on Thu Apr 11, 2019 12:12 pm
You'll want to set up two triggers.
Log into Adafruit IO and visit the trigger page
https://io.adafruit.com/triggers
From there, you can create a reactive trigger. Select the temperature feed, and set the comparison to greater than 27.
For the trigger's action - you can select the motor feed and set it to a value.
You would need another trigger to perform another action.
brubell
