Inbound Webhook Actions
by TheBrewery on Thu Apr 11, 2019 4:18 pm
Hello All,
Is there a way to trigger an action on the board (like I can do in Dashboard) from an inbound webhook, IE iBeaon event sends webook to IO and causes the associated case to fire?
Mike
TheBrewery
Re: Inbound Webhook Actions
by brubell on Thu Apr 11, 2019 5:00 pm
You'd need to take care of this in code by listening to the feed's incoming value from the webhook, either by polling the feed or subscribing with MQTT. Then, you'd handle the action.
brubell
by TheBrewery on Thu Apr 11, 2019 5:27 pm
Sorry I am still really new to this...
is this what you mean?
// set up the Adafruit IO feeds
AdafruitIO_Feed *lightRing = io.feed("light-ring");
If I press one of the virtual buttons in the dashboard it triggers correctly, however, I cannot get data to input from the API using Postman... Also if I manually add the data in Feeds using the "+ Add Data" button it does not trigger the light ring. So I assume I am missing something on the board side?
Mike
TheBrewery
by TheBrewery on Fri Apr 12, 2019 11:15 am
When trying to send the API call I keep getting this error...
    "error": "request failed - failed to save data to feed trigger. undefined method `>' for nil:NilClass"
This is the call that I am sending...
curl -X POST \
  https://io.adafruit.com/api/v2/webhooks/feed/***TOKEN*** \
  -H 'Content-Type: application/json' \
  -H 'X-AIO-Key: ***TOKEN**** \
  -d '{
   "value": "in-use"
Help please
Mike
TheBrewery
by brubell on Mon Apr 15, 2019 10:32 am
This error has been fixed and should be displaying the correct error text.
brubell
