Black Lives Matter - Action and Equality.
stream widget going extra with error reporting
by ductsoup on Thu Apr 11, 2019 9:02 pm
I configured two of these blocks to display six feeds for a prototype project. Noticed it seems to also be reporting (expected) errors from all my feeds. Think it should be reporting data and errors from just those feeds that were configured.
https://io.adafruit.com/ductsoup/dashboards/lora
The unconfigured feed is a TCS34725 mounted outdoors. If it's too dark it doesn't report RGB so AIO reports it as an error but it's really the expected behavior.
ductsoup
Re: stream widget going extra with error reporting
by brubell on Fri Apr 12, 2019 12:16 pm
We don't differentiate errors in the {username}/errors topic, so Adafruit IO wouldn't filter by feed here.
Could you add this as a suggestion to Adafruit IO Blocks here: viewtopic.php?f=56&t=130408
brubell
by ductsoup on Sat Apr 13, 2019 8:40 am
Got it, thanks
ductsoup
